i give up
Old 09-11-2008, 06:32 PM
DelGatoGrande
My Feedback: (23)
DelGatoGrande's Avatar
Default i give up
guys i can use some help here please..[]
i got a raptor60v2 and in the last two months i spent fuel only
trying to find whats whrong with my tail...
tail walks slowlyto the right(left rudder) and from time to time it gives violent left ruder
i have upload a video for you..
http://www.youtube.com/watch?v=f16ErTgfWjY
0:28 notice the violent left rudder/not my input.
during all the video i never use left input on the stick only right to corect
spesialy at the end notice the tail walk alone..
some one sed it was un balanced cooling fan...i got a new one on..
i flew with a jr500t no one owned it around here to help set it up so they sed must be the gyro.
i got the futaba 401...video has the 401 on...same think again...
i realy cant enjoy my heli.any idea guys?
thanx[8D]
Old 09-12-2008, 02:30 AM
gj1803
Default RE: i give up
Hi Delgratogrande,
First of all, I would put your tx/gyro in rate mode, centre your tail trims (including sub trim) then alter your tail linkages till the heli hovers without turning left or right. Now, when you go back in to HH mode the heli should stay where you put it. You may want to check you have enough servo throw and that your tail slider etc are all in good order.
Try this and you should be OK.
GJ
Old 09-12-2008, 02:45 AM
Charlie
Charlie's Avatar
Looks like a glitch, what are you using for a radio/receiver, pcm/ppm/2.4? Have you tried moving some of your wiring around (maybe move your antenna to the other side of the heli). It could be a bad bearing causing radio interference. Your going to have to try different things (trouble shot) to see if you can find the problem.
It might not be your gyro at all (I see you tried two different ones and it did the same thing), it could be some kind of radio interference. If you have radio interference "USUALLY" the first place you will see it is in the tail.
Old 09-12-2008, 09:16 AM
DelGatoGrande
My Feedback: (23)
hey Charlie ! i use futaba 14mz fasst2.4 //this is not a glitch for sure
Hey GJ this weekend ill set it up again from the start and let you know..
forgive my bad english
thank you alot for your time guys!
best regards
George
Old 09-12-2008, 09:51 PM
matador_24
for what I see, I think that your GAIN is too low...
usually you have to increse the % of gain from your Transmiter and stop until the tail starts kicking when you give rudder.... once that it kicks, then decrease a couple of points the gain until stops kicking and it will be rock solid.......
go to www.raptortechnique.com you will get lots of info about setting properly the gyro for the raptor....
Old 09-17-2008, 02:00 AM
mr502go
Did you use foam tape to mount the gyro?? Futaba sells the stuff I think you usually get three squares of tape per package, stack all 3 and mount your 401 with that stuff, it helps damp vibrations, and keeps from "confusing" the gyro.
Old 09-17-2008, 02:03 AM
DelGatoGrande
My Feedback: (23)
hello!
yes i have use the foam mount...but its not that []
now i like to try to change the rudder servo ...maybe this is
thanx for your time
Old 09-19-2008, 12:58 AM
elecfly
what tail servo asre you using?
Old 09-19-2008, 01:10 AM
DelGatoGrande
My Feedback: (23)
http://www.horizonhobby.com/Products...rodID=JRPS810G
Old 09-19-2008, 01:31 AM
elecfly
Is the gyro set to use a non digital servo? the servo is too slow for the gyro
get a flippen 9254 !!!
Old 09-21-2008, 07:30 PM
TyD
If you guys figure this out PLEASE post the results on all the other forums because it is not just a RAPY problem.
Old 09-21-2008, 07:33 PM
DelGatoGrande
My Feedback: (23)
what you mean "RAPY"??
Old 09-22-2008, 12:46 AM
elecfly
think he means raptor
Old 09-22-2008, 02:10 AM
DelGatoGrande
My Feedback: (23)
da..[:-]
thanx elecfly!
at this time i change radio receiver since futaba 2.4 has lowervoltage signal from there receivers and maybe this is//ill get back
Old 09-22-2008, 02:20 AM
bladeskiller
In case of using an analog servo ,you have not only set the DS switch at OFF position but also you have to adjust the DELAY trimmer. Turn it all the way to the left (0%) and start giving more and more delay, untill your tail is steady.
You have better to use a good digital servo, like futaba 9254. I use it on my raptor 30 with a GY-401 and the tail is really steady. I use futaba 2.4 receiver too.Using a digital servo, you have to set the DS switch at ON and the delay trimmer all the way to the left (no delay).
For AVCS mode, make sure that rudder mixing is set to zero (no rudder mixing) and the gyro gain is set above 50%. You have 50 units margin not 100, so if you want for example 84% sensitivity in AVCS mode, you should set gain channel at 92%.
Kostas from Athens.
Old 09-22-2008, 09:53 AM
BarracudaHockey
BarracudaHockey's Avatar
ORIGINAL: mr502go
You only use 1 square to mount the gyro with. If you're using 3M outdoor mounting tape, which works well, better than the stock foam really, then use two layers.
Old 09-23-2008, 06:41 AM
DelGatoGrande
My Feedback: (23)
hey guys![8D]
first i like to thank all for your posts!
lust night i removed the radio i had on the heli/14mz 2.4 with 14 chanel receiver
and install my futaba 9cap on 35! i change back to crystal..with r149dp
......promblem solved...at least until now...i flew it 20 minutes and the tail was solit!
ill also go back to the j500t gyro the next day and let you know
.....there is an issue with the new 2.4 receivers of futaba /they have week signal(white cable output) and other units cant read it..so this must be it!
the solution is signal amplifiers like this one ill get soon:
http://www.powerbox-systems.com/e/we...rker/start.php
heli now fly steady and nice
again thank you all for helping!
rcu to its best!
best regards
George
p.s.kosta efxaristo file
