Throttle arm
Ran my engine for the first time yesterday, was very impressed, standard out the box tt.39 in the raptor 30 V2. only 1 problem though which I thought I should tell you all. The nut holding the trottle arm onto the carb is not tightened very well and at the end of the tank was loose the the servo was swinging it freely without effecting the carb at all because the nut had come loose. Checked all the other factory tightened nuts and they seemed fine. Something the check on the ARTF raptors.
RE: Throttle arm
Careful when tightening this.
I have bent an extended throttle arm and am struggling to find replacement parts. Can anyone point me in the direction of a UK or US based OS Engine parts seller ? |
RE: Throttle arm
Look at www.quickuk.co.uk
They have extended throttle arms for OS engines. They can be bought from almost all heli stores in the UK |
RE: Throttle arm
Thanks Siclick
I should have thought of them - after all, most of my other parts have been QuickUK parts..... |
