Preventing Accidental Throttle-Up
Is there a way to prevent throttle-up while carring the Helicopter? I am very nervous carrying the Heli and Radio while the engine is running. The thought of accidently hitting the throttle stick is scary... my radio is a 9cap
RE: Preventing Accidental Throttle-Up
Easy set the throttle hold for the same percentage as idle on the throttle stick
Easy enough, thanks...............
It's usually best practice to put your thumb on the gimble above the stick while carrying the radio. This allows you to give a small bit of throttle if your engine loads up but also prevents the throttle from being hit accidentally.
You should get into the habit of settng the throttle hold when starting it up.
sorry, don't mean to hijack the thread, but since my engine was in the heli when I bought it, and I'm yet to test the engine or install the throttle servo, which way should the throttle lever turn to close the throttle........if I'm looking at it from that side of the engine? I'm scared of starting it up with the throttle open :)
What type of engine do you have? My OS manual shows a mark on the Carburetor Rotor, when this mark is pointing towards the intake its wide open or also all the way right is closed and left is open. This is for a OS 37SZ..
I had the same fear! |
I just hit the throttle hold switch and start it up. Then when the heli is on the ground and ready to go flip the switch and hit the power.
ORIGINAL: H0ndaJunkie sorry, don't mean to hijack the thread, but since my engine was in the heli when I bought it, and I'm yet to test the engine or install the throttle servo, which way should the throttle lever turn to close the throttle........if I'm looking at it from that side of the engine? I'm scared of starting it up with the throttle open :) Good Luck, d.tipton |
The best way to check the throttle the first time you start the engine is leave the glow ignitor off. Turn the engine over with the starter and see what the engine sounds like. If it sounds loaded, then you have the throttle wide open. If it sounds pretty lean and quick, then it's closed (or idle).
ORIGINAL: Motions It's usually best practice to put your thumb on the gimble above the stick while carrying the radio. This allows you to give a small bit of throttle if your engine loads up but also prevents the throttle from being hit accidentally. |
I have attached a rubber band to the handle, run it down the back, across the bottom and up to the throttle stick. Works in a pinch. Just pop it off and you're ready to go.
Start it in throttle hold, leave the glow starter battery hooked up till you set it down and then pop it off and throw it in your pocket (no keys or bullets in there is best) and you have the best of both worlds, the thumb method wont work of you trip over something or drop the transmitter.
