servo selection
Totally newbie to heli's here so I will probably have a few ? in the next few weeks.
I plan on starting assembly on my new Raptor 50 V2 kit soon.I'll be using a S9253 tail servo and a 401 Gyro but am wondering what I can use that will be cost effective on the other locations. I already have some new Hitec 425s BB as well as some Futaba 3004s from my planes. Consider that I will be primarily just learning to hover and doing the basics for quite a while so the servos will not be subject to violent 3 D maneuvers. When at a later date I "need" high quality servos because of improved skill level, I will be more than happy to buck up for the "good stuff" In the meantime Will the 425s or 3004s work ok or can you recommend something that will- and not break the bank. Thank you, Dwight Hayden |
servo selection
I used all 425s on my old Kalt Space Baron S (Enforcer ZR) so you should be fine with those.
I use all JR digitals on my R30, 4 x DS811, 1 x 810G. |
servo selection
Thanks for the info!
Dwight |
| All times are GMT -8. The time now is 12:22 PM. |
