Removing Spinner
OK
I am trying to remove a spinner, but the screws are so reamed out, that a screwdriver just revolves and can't get a bite. What is the best way to attack this problem? Thanks. Jim
At this point, you can try useing a drill bit to drill off the heads. The screws should only be attached to the spinner back plate at this time & the front half of the spinner will pull off.This will probably leave you with a useable spinner.( a left hand drill bit would be even better if you have access to them, since it may back out the screw while you are drilling) If that doesnt work, try cutting it apart with an X-acto blade in a soldering gun, till you can get to the screw heads with a pair of pliers & turn out the screws. Either way you'll get it off. Good luck with this......Gene
A star type driver with the tip edges sharpe will sometime do the trick, The tipe must be a little smaller than the phelps head. This will also work on the allen head.
OK
Thanks for all the good advice. I eventually had to do it the old fashioned way.( I didn't like that spinner anyway!) However, from now on I am definitely going to stick with Allen bolts.
