 smoke systems >
smoke systems
smoke systems
Old 11-28-2010 | 12:42 AM
rye
My Feedback: (10)
Default smoke systems
hi i am using the tmc smoke system on a dle-20 where and what size nipple do i drill and tap for thanks
Old 11-28-2010 | 07:17 AM
scale only 4 me's Avatar
My Feedback: (158)
Default RE: smoke systems
You just want to match it up to the tubing you'll be using, tower recommends this one with that pump
http://www3.towerhobbies.com/cgi-bin...?&I=LXD623&P=M
Tip
If the line melts off being the nipple is too short/close to muffler, solder on a 1" length of brass tubing to the nipple, that help disperse the heat and the tubing doesn't have to be right up tight to the muffler.
good luck
Old 11-28-2010 | 09:36 AM
rye
My Feedback: (10)
thank you ,lol i have every size but the 8/32 my luck [:@]
Old 11-30-2010 | 10:00 AM
My Feedback: (158)
use the 10/32, it would work ok I'm sure
