"Glazing Putty" for balsa?
If you are not concerned about weight that works fine. Epoxy is much too heavy to use as a filler. Lightweight filler under the glass is considerably lighter with no strength penalty.
Hi!
And to be honest... I tend to stay away from using microballons/epoxy at all prior to covering, I sand! But Brown microballons is not heavier than light weight spackle and if you use the right sanding cloth available (with is Hiolit 80 by Mirka and then use the best sanding paper on the market which is "Rhynodry plus" Red Line from Indasa (Portugise company) sanding is just a joy.
#33
I use the lightweight spackle, the Elmer's wood filler, micro balloons, whatever seems best for the situation. I think I'll pick up a tub of the Rock Hard filler to try out.
Now, if you want good sanding results, try the 3M Sandblaster Pro. This stuff is amazing! It's very flexible silicone instead of paper, and is available in sheets or rolls. Printed right on it is the claim that it lasts 10 times longer, and it must be true. Put it on a pad, or wrap it around a dowel, or "shoe shine" it. It's available in 100, 200, and 320 grit for any situation.
#38
#40
#41
My thinking is leaning more to using it for fillets, where I think its strength and rigidity will make it quite useful, plus its cheaper and easier to use than epoxy and microballons. As a regular filler, I'm not sure it'll have any advantage since its harder to sand than say the Elmer's product.
#43
Did you experience issues with it flaking, or coming off in chunks ?
#44
My Feedback: (158)
Yes,, right where it got paper thin, but that was easy to repair and flair back in with light weight spackle
The biggest issue with that stuff was for the life of me I couldn't get the monokote to stick to it, the inside curves which are always tough were impossible, II had to cut it back and paint the fillets..
I'm sure it would be fine for a glass/paint process
#45
#46
"The Builder" on RCG builds DLG gliders. He makes his own molds and mixes epoxy with the rockhard putty for his molds. I did a mold for a duck call reed holder for a friend of mine using the epoxy/putty mix. It is very stable and very hard/tough. Sanding will be accomplished using power tools for anything meaningful.
I don't know if this info would be of use to anybody but thought I'd throw it out there.
Ken
Ken
#47
Last summer I bought some Red Devil "One Time" light weight spackling to fill some holes and rough spots in the walls of our clubhouse before repainting. I applied it to some very shallow gouges in the drywall and after two and a half days the spackling still wasn't dry! I had to use a heat gun to dry it enough to sand it down.
I have read that some light weight spacklings do not dry as well as they used to. This was Red Devil brand so I'm not sure about the other brands.
