Reload this Page >
Write-up: Installing a Bowman ring in a DLE-20
Old 02-04-2013, 06:05 AM
grosbeak
grosbeak's Avatar
Default Write-up: Installing a Bowman ring in a DLE-20
Last last year I ordered a Bowman ring for my the DLE-20 on my Pulse 125. When I ordered the ring I told Frank Bowman I'd take pictures and do a write-up - so here it is!
Note that you can do this with the engine in the airplane, but for the reed valve mod which followed it had to be removed.
1. Remove the spinner and propeller
2. Remove the cowl
3. Remove the muffler
4. Remove the throttle and choke linkages
5. Remove the engine from the plane
Old 02-04-2013, 06:10 AM
grosbeak
grosbeak's Avatar
Default RE: Write-up: Installing a Bowman ring in a DLE-20
6. Remove the cylinder head bolts
7. Separate the cylinder head from the crankcase
At this point I took a close look at the stock ring. It was loose in the groove and easily moved and it was almost ready to fall out.
8. Remove the stock ring - start at one end and work it over the top of the piston.
Old 02-04-2013, 06:17 AM
grosbeak
grosbeak's Avatar
9. Roll the Bowman ring around the groove to ensure there's no binding. If there is, clean the groove with a piece of the old ring or a wire brush.*
10. Sand the piston sides lightly with some 600-grit Emery cloth.*
11. With the notches facing up, work the Bowman ring into the groove on one side of the pin.
12. Work the ring around the piston until it's all in the groove.
*per Frank Bowman's instructions
Old 02-04-2013, 06:23 AM
grosbeak
grosbeak's Avatar
13. Work the cylinder head back over the piston
14. Put some thread lock on the cylinder head bolts
15. Reinstall the cylinder bolts.
At this point you could reinstall the engine in the airplane, but I still had to do the reed valve mod. Write-up and link to follow.
Old 02-04-2013, 03:35 PM
Bluelt
Thanks for the write up!  What is the cylinder bolt torque? Thnaks
Old 02-04-2013, 04:27 PM
acerc
acerc's Avatar
Great write up grosbeak. I have his rings in all my engines.
I have a question, did you put any oil on the ring and cylinder wall prior to instalation.
Old 02-04-2013, 07:53 PM
karolh
Sure hope that he did.
Karol
Old 02-10-2013, 04:37 PM
tailskid
My Feedback: (34)
tailskid's Avatar
He gets "5" more points for this write up!
