Reload this Page >
Painting MonoKote?
Painting MonoKote?
Old 06-25-2016, 08:42 PM
JeffT
Default Painting MonoKote?
Has anyone ever had luck painting MonoKote with acrylic airbrush paint?
Old 08-14-2016, 06:48 PM
gratter
I have used this on other projects but not on Monokote but Duplicolor makes a clear adhesion promotor for painting plastics. Might help.
Old 08-14-2016, 07:57 PM
JeffT
Thanks! The Duplicolor web page says it is for enamel and laquer, but I would guess it would work with acrylic paint too. I will give it a try. Thanks again!
Old 08-15-2016, 01:35 PM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
Sanded covering with 440, primer was rattle can Rustoleum auto primer, then Behr Latex with an airbrush
http://www.rcuniverse.com/forum/ques...ainting-4.html
ID:	2177031   Click image for larger version
Old 08-15-2016, 02:06 PM
gratter
Is the monokote over solid balsa? Wondering what it would do on open framework.
Old 08-15-2016, 03:25 PM
extra300crazy
extra300crazy's Avatar
At one time Monocote was available in clear, which had a somewhat frosted surface to provide a "tooth" for the paint to adhere to. I used it once with good results.
Hope this helps.
Karl
Old 08-15-2016, 08:46 PM
tailskid
My Feedback: (34)
tailskid's Avatar
Jeff, what you thinking of painting?
Old 08-16-2016, 02:14 AM
scale only 4 me
My Feedback: (158)
The fuse is fiberglass, but the wing has open framework, latex is pretty flexible, seems to expand and tighten up with the covering just fine out in the sun.
Old 08-16-2016, 03:19 AM
JeffT
I want to paint some graphics on a Great Planes UltraSport, and stripes on a Goldberg Eagle 2, both covered in MonoKote. I have a lot of Createx and AutoAir acrylic paint that I have been using on rockets for a while.
Old 08-05-2023, 09:22 AM
Hyjinx
Hey contributors
Wondering if anyone has specifically painted monocote successfully. I have a great planes super Stearman which has white monocote with red stripe details as per factory. I want to PAINT not recover the fuse to USAAF deep navy blue to mimic the Military PT-17 as my dad was USAAF in WW-2. Any firsthand experience with this? Thanks in advance.
Hyjinx (Aaron )
Old 08-08-2023, 11:03 AM
Hyjinx
Originally Posted by Hyjinx
Hey contributors
Hyjinx (Aaron )
Help from the black hole lol
Anybody still active for this question?
Old 08-09-2023, 08:08 AM
mgnostic
mgnostic's Avatar
It's been a long while since I last painted Monokote but one of the important things was getting it really clean. Lightly scuffing with very fine sandpaper helps but it also seemed to help if it was wiped down with cleaner/degreaser fir automotive paints. Iron on coverings seem to often have some sort of lubricant or other contamination from the manufacturing process. Once it is clean, wear rubber glove and don't get fingerprints on the covering. I presume this will be an electric powered plane since there was no mention of fuel proofing. If the surface is prepped the paint should stick as well to Monokote as any other plastic.
Old 08-18-2023, 07:30 AM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
I’ve painted over Monokote once. Didn’t work out too badly. The paint held up fine and I could even tighten up the Monokote when required. That said, I prepped the surface with 800 grit and wiped with acetone. Then the paints used were DuPont Chromabase/clear.
Old 08-19-2023, 08:17 AM
Hyjinx
Thank you for the response. It will have a radial nitro engine. (Most of my planes are radials running gas or nitro) pretty judicious about not letting the fuels get away from the tanks and exhaust for ending up on the fuselage's.
Thanks for the helpful writing!
Aaron- (Hyjinx)
Old 08-19-2023, 08:22 AM
Hyjinx
Thanks also. Really appreciate you folks chiming in. Sounds like an acrylic laquer or automotive urethane.
I have a BUSA 1/3 scale painted with auto urethane that holds up well to gas, but it is covered with orocote. Monocote is a whole different deal. No one at my club has had good results, but you know how that is. Usually those with bad experiences are the most vocal. Lol.
Thanks again
Aaron-
Old 08-19-2023, 05:38 PM
mgnostic
mgnostic's Avatar
Thanks again
Aaron-
Monocote application is a skill like any other in our hobby. I know a couple of fellows whose skill with it is truly professional grade. Me, not so much. I get by but I prefer Koverall. Apparently Monocote got reformulated a couple of times and there are those who swear by one vintage or another.
