How to repair dents in EPO foam >
Old 11-05-2016, 05:17 PM
Default How to repair dents in EPO foam
I have a Dynam Pitts (EPO foam) that I sprayed with multiple coats of clear acrylic.
It makes a nice, more durable finish, but it dents quite easily.
Does anybody have a good idea on how to "repair" the dents?
Somewhere I think I saw a recommendation that applying a hot towel (wet maybe) would lift the dents.
Any ideas??
Old 11-06-2016, 06:37 AM
kenh3497's Avatar
Wet paper towel and a monocoat or other hot iron. You will hear the water sizzle as the iron is applied. Don't leave the iron on too long as you could melt the foam. Safe is when you stop hearing the sizzle remove the iron. Actually remove the iron before the sizzle stops The steam penetrates the dented foam and "blows" up the dents.
Ken
Old 11-06-2016, 08:03 AM
Thanks, Ken
I guess that was the technique I had heard about.
Do you think it will work after I sprayed a few coats of acrylic clear on the foam?
Old 11-07-2016, 03:07 AM
TomCrump's Avatar
Originally Posted by dksnyder
Thanks, Ken
If you already have the foam sealed, the water/steam will have trouble penetrating into the foam. If it does somehow penetrate, the steam will destroy the clear coat.
Old 11-11-2016, 05:06 PM
kenh3497's Avatar
Ya what Tom says. On my DLG that has light fiberglass and very little epoxy in the glass it works fine. If you have some foam scraps round you could prep them in the same manner as you plane and then experiment a bit to see what happens.
Ken
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
