Klass Kote epoxy primer >
Old 02-19-2017, 09:32 AM
My Feedback: (30)
Unhappy Klass Kote epoxy primer
I read in some resent forum that Klass Kote makes a yellow primer. Now this is a good thing since most any yellow paint topcoats require several coats since they don't cover very well. I contacted Klass Kote and found that they do make the yellow primer but it is unfortunately only available in 1/2 and 1 gallon cans. Tough luck. ' buff
Old 02-21-2017, 03:40 AM
My Feedback: (158)
scale only 4 me's Avatar
Yellows reds and oranges are always a challenge to get a good even coat without using a ton of paint,, the best thing I've found is making sure you have a perfect solid white primer coat,, and I mean "solid" white,, any little mark or thin spot will show through the yellow.
good luck
Old 02-21-2017, 09:16 PM
Blend in some yellow paint with the primer. You'll never know the difference in primer buildup, and you'll get the yellow under-base you are looking for.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
