Reload this Page >
Tool for spreading clevises
Old 03-23-2017, 05:52 PM
Leroy Gardner
Default Tool for spreading clevises
Having a problem getting your clevises connected, do as I did and make a simple tool.
using a small screw driver solder a small piece of brass to it and file both sides the width of a 4-40 clevis leaving small ears so it don't come off connecting it to your servo arm, I made mine 3/16" wide and it opens 2-56 & 4-40 clevises making it easy. You may half to squeeze it a bit with long nose pliers to get the clip on but it's no problem. Just insert between clevis arms and twist.
ID:	2206723   Click image for larger version
ID:	2206724   Click image for larger version
Old 03-24-2017, 05:41 PM
Tom Nied
Tom Nied's Avatar
I just use an appropriate sized screwdriver. But if something like that helps a person, Great!
Old 11-14-2017, 06:23 PM
mkjohnston
Hi I know this is a little late but Dubro did make a simple clevis tool that you insert into the space behind the pin and you turn it right or left and it will open most clevises.
take care
Michael
Old 05-03-2018, 06:05 AM
r ward
I think Dubro calls them "screwdrivers".
Old 05-08-2018, 03:40 AM
OldScaleGuy
OldScaleGuy's Avatar
Great idea. Thanks for sharing.
