Best Work Bench Top
My Feedback: (8)
KS
Best Work Bench Top
Getting back into building after several years absence. What are ya'll using for work surfaces? I recall using a solid wood door years ago and it worked well. I was thinking of using a 3' W x 8' L counter top for a work bench. Any suggestions or comments?
Thanks, Randy
Thanks, Randy
RE: Best Work Bench Top
I use a wooden door and on top of that 2 inch thick blue foam, workst great for me.
If you use a door, leave it flat all the time, if you put it on it's side to make some space it will bend.
I've been using a hollow door with nothing on top. Needless to say I don't stick any pins in it. I also us a large glass storm door for gluing sheeting together.
Tom
Tom
NH
It all depends on how much you build and how long you plan to stay in the hobby. I have a 4X8' 1/2" thick sheet of tempered glass for my build table. It costs a bit, but will last a lifetime and will always be flat and solid. After building on glass, I can't believe I ever used anything else. Best surface ever!
Hans
Hans
20 years ago ago I made up building boards from 12" x 1/2 " luan veneered shelving with 1/4 inch fine grained (bulletin board) cork cemented to one side.
I made one 6 ft long for fuselage and wing panel construction, one 2 ft long for stabs and elevators and one 12" x 12" for vertical fins and rudders... Since I like to use Aliphatic resin for most structural joints, three boards allow me to build one part of the airplane, then set it aside to dry while I work on another, and they are easy to store when not building.... FWIW, the boards are still flat -
Cheers!
Jim
Cheers!
Jim
ON, CANADA
building-hollow core door with 1/2"x 2x4 ceiling tile. 1 1/2'x6 ' x 1/2" thick sheet plate glass for cutting coverings (from a home reno project that was just going to be tossed out).
I use heavy timber for the bench itself, nice and flat. On top of that I have a sheet of that fibrous stuff used for notice boards (can't remember its name!) in an alloy frame. This stays flat on the bench top but is really easy to pin to. It's not expensive, so if it starts to look a little tired you just pull it out of the frame and fit a new piece.
FL
ORIGINAL: Heavy Date
Hans
Hans
BTW, the bench top and the building surface should be two separate things in most cases.
WA
I have an 8' section of a bowling alley on top of a 4x4 and 2x6 frame.
I found it at the local lumber yard where they had bought them from a demolition.
It is quite stable and level.
When building, I place a sheet of 'hobby board' on top of it that the lumber yard stocks. This is a fibrous (sp?) board that pins stick into quite nicely.
Any plywood from 1/2" thick and up will work, better if you bolt it to some supporting frame tom avoid warping. Also very useful is to use floor wax on the top surface to or 3 times polishing it until it shines...it ensures you that any cyano or epoxy will be easily removed, I wax my own board from time to time and it seems like new.
Tato.
Tato.
My Feedback: (14)
I built a table out of plywood and 2x4s. I have a large piece of plate glass that I lay on top of it when I need a flat surface. I have seen building tables made out of melamine, a plastic covered particle board. When I up grade that is what I plan on using.
Eric
Eric
I have a 4x8 sheet of particle board that I set either on saw horses or on my table saw (fence removed of course).
On top of that I have a sheet of 3/8" drywall that allows me to pin into, cut on, tape plans to, jot down notes, mix glue on etc.
Once the drywall gets to beat up I just pitch it and get another.
BTW, PARTICLE board is MUCH flatter and more stable than plywood or OSB.
NY
I have two benches both made from hollow core doors. One sits on sawhorses, and the other I built legs on using PVC pipe and screws. I just push the t-pins right into the door. Go to your local big-box hardware store and ask for damaged doors. Usually one side will be damaged, but the other side will be fine. You can get them for a big discount. If you can, get wood skin doors, not the composite stuff. The wood is easier to push the pins into. If you want, put ceiling tiles on top of the door for easier pin installation. I just don't like ceiling tile material. It makes my arms itch and are messy. Being an electrician, I am in ceilings every day. Anything to take my mind off of work is a good thing. Ceiling tiles just remind me of work too much![:'(]
A friend of mine is getting ready to convert one bay of his garage + 3' into a shop. For the work benches I was given by my daughter's work two 4' X 10' X 2" solid doors. One side of the doors are white and the writeable material that is used on white boards for classrooms. They are really pretty and heavy and flat.
Lee
Lee
NH
I use a piece of reinforced melamine that I contact cement a piece of sound deadening material (the dark brown stuff). Holds pins perfectly and stays nice and flat
I have a BUILDING Bench made from 5/8 plywood and 2 x 4's, supported in several places to keep it flat. The best material I have found for the top is called SOUNDBOARD. I've been using it for 20 years and 4 different benches. It's available from most lumber yards and is used as underlayment for floors. (I've never seen it in home improvement centers so don't even bother looking there).
It is a fiberous material, about 5/8" thick and pins stick easily and stay put. I screw the soundboard to the ply sheet using drywall screws. I've found that this surface tends to last me 5 years or more and then I turn it over and use the other side. It's not expensive and I recommend you check it out if you like to build kits using pins. I've tried building on glass and while it has some advantages, I like soundboard better. For other benches I prefer masonite or particle board. Soundboard is used only on the building bench. My two cents.
Chuck
Chuck
I've used a hollow core door with a sheet of Celotex insulation on top. It's worked well for the last 10 years although I have replaced the Celotex once.
