Dow Blueboard
Hi there....
Does anyone have a source for the 1" and 2" Dow Blue foam board in the Houston TX area. I live in Orange, about 2 hours drive from Houston and I would be willing do drive to get some...I'm getting desperate...I need several Sheets..
Thanks, Benny
Thanks, Benny
IL
I get mine at Menards. Also, you could try lumber yards or builders supply. All it is is foam insulation, frequently used to insulate concrete foundations. The 2" thickness may be a problem, I only remember seeing 1". Another source would be construction companies that specialize in insulation. Your phone diectory yellow pages would be a good source. Good luck. Regards.
