Keeping glue tips clean, addendum >
Old 09-09-2002, 01:00 AM
Default Keeping glue tips clean, addendum
For those of you that use acetone to keep you glue tips clean, make a mental note of this. I like to use CA to help hold the charge connector into the recepticle mounted to the side of the fuse. Today I removed this recepticle from a no longer used airplane and decided to soak the piece in a bottle of acetone so I could reuse it on my new Morris the Knife.
The acetone not only desolved the CA but also the charge connector and wiring insulation in about 3 hours. I was running a Futaba switch harness. Use caution with acetone as this is a very powerful solvent.
Old 09-09-2002, 01:10 AM
My Feedback: (506)
Acetone will attack most plastic canopies. Learned that the hard way.
This dissolving trait can be put to good use. A quick wipe of acetone on plastic parts roughens them slightly - this is a great timesaver when I'm gluing *anything* to plastic.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
