Removing a hinged surface? >
Old 09-19-2002, 07:02 PM
Default Removing a hinged surface?
[ I also posted this in the kit building forum... wasn't sure where the best place was so I am posting here also ]
I am trying to figure out what is the best to remove the rudder and elevator surfaces from my plane without tearing it all up. I want to replace the two surfaces while I am converting the trike gear to tail-dragger. I have the new pieces built but I don't know how to get the hinges our of the vertical/horizontal stab.
Any suggestions?
Old 09-19-2002, 07:47 PM
apbonura,
My quick and dirty side wants to suggest that you just cut off the existing hinges flush, and rehinge in different spots. I'm sure that 's what I would try first in your spot. If you're lucky, someone here with have some magic glue-releasing trick that you can use instead.
Good luck,
banktoturn
Old 09-19-2002, 07:58 PM
My Feedback: (10)
C_Watkins's Avatar
I'd have to second that emotion... especially if they're CA hinges or similar.
Slice 'em flush, re-hinge in a slightly different place, if feasible.
Old 09-19-2002, 08:12 PM
Default Slice 'em!
That should work!
Thought there might be some secret to it, but I guess it's just like anything else... the simplest solution is the best solution!
Thanks guys.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
