Removing Anodizing
My Feedback: (18)
Jetpack try Tim at HyperColor Anodizing www.hypercolor-anodizing.com He does all my anodizing on my show engines and such and should know the best way to remove it.
Bob Harris
Early RC Models
www.earlyrcmodels.com
Bob Harris
Early RC Models
VA
Here is a post I made, quoted, from the other side of RCU... Oh yeah EZ Off (Easy Off?? I forget how it's spelled) is the brand we use, get the "original".
ORIGINAL: Frost_
It is VERY EASY.
Go get some oven cleaner. I use a glass caserole dish to hold the parts, and coat them with the oven cleaner. After 2 or 3 mins, wash the parts off PROFUSELY with warm water. This process needs to be repeated until the parts are 'clean'. Some comes off fast, and some well... If you find some stubborn parts, using GOGGLES or some kind of EYE PROTECTION and GLOVES, and after the cleaner has sit for about 30 seconds or so, use a toothbrush on what's left. This has always worked on stubborn parts for me. If you leave the oven cleaner on too long, it WILL make dark spots on the aluminum that are practically impossible to remove.
Now, to make it look GOOD... Buy yourself some Mother's Aluminum polish (auto parts store) and in 30 seconds, you will be looking into a mirror.
The first parts I ever stripped were lower arms on my Savage and I was IMPRESSED by how quickly the stuff just runs off... I don't have any pix handy of mine to show, but that night I told Amsterdamn and he did the same to parts of his Evader. Here is a quoted post from a video-forum thread that has pics of the oven-cleaner/Mothers, stripped aluminum. Yes, this was his first try too.
It is VERY EASY.
ORIGINAL: Frost_
Last Sunday, Amsterdamn and I had a few of our RCs that don't fly, out at the flying field. He had his gorgeous, all-aluminum Evader out for a beating. The truck, as it is in the vids, is sporting some rather large Masher 2Ks, an OS18 CV-R, 4 shoe clutch, and entirely too many other odds and ends to mention.
These videos are SICK, this truck is SICK...
You guys wanna see what wheelies from 20 MPH with Mashers look like? ....over and over? You think an all aluminum truck is too heavy to be fast? You have to check out these vids. I had my 1/8th scale buggy out there with a monstrous Collari .30 and as fast as it is, the Evader wasn't very far behind in the straight line blasts from a standstill. Oh yeah, did I mention, there are almost NO stock pieces left on the truck.
Here are some pics, under them is a link to an open directory. Go to the directory and right-click and choose save-as to grab the files. Anybody know the bands in the two videos?
Here are the videos already!!!
Number 1 is 5.2MB and number 2 is 4.5MB, so you can get 'em with dial-up too...
http://www.post911timeline.org/ameri.../New%20Evader/
FL
Easy-off is the easiest way to remove that stuff other wise you'll be sanding till your fingers fall off.......it can be a mess though....to keep it clean if you have an orbital sander w/120 grit paper that works well to with less of a mess, just sand it right off.....if you go the ez-off way then spray it on....let it sit for 15 min then wipe with a damp sponge....then sanding by hand is a breeze. Just don't get this stuff on anything else because it will stain the hell out of it..... Hope this helps
Shawn
Shawn
Well, I tried the Easy Off and it worked well on removing the anodizing, but it blackened the part just as Easy was doing its thing. Since this was an old spare, I decided just to let it blacken all the way...just to see how far it would go, or if it would damage beyond repair.
After about fifteen minutes, the easy off stopped bubbling and the part was completely black. The chemical process had stopped. I rinsed the part and it had a well coated patina finish, but easily rubbed off in spots, leaving it looking like nick and dent special. Other spots were harder to remove just by rubbing with my finger or nail. I could tell this finish was not going to polish well, as it was pitted now.
Knowing this blackening was from oxidation, I decided to use TarnX (silver dip) to remove the blackening. After a short five to ten minute soak, all the blackening had vanished leaving behind what looked like a galvanized finish, all bright and silvery....with a grain pattern to it.
I suppose the easy off crazed the aluminum, but the blackening hid that until it was washed off by the silver dip solution. Not really what I wanted to see for a polishing base, but like i said this was just a trial deal, and to tell you the truth, I kinda liked the effect that it gave after all and decided to keep it. I included a couple pictures below for you to see, and tried to capture the grain of the aluminum the best I could. Both pictures are of a Cox TD...one just has the needle valve body done, and the other has the body and the venturi done this way.
VA
I don't leave it on more than 2-3 minutes. Most parts take 2 to 3 applications, but you don't have any of the pitting or blackening. Keeping it short provides the perfect surface for polish, look at the chassis in the pic, you can see yourself in the flawless bottom... We used Mother's polish on all the bits.
I can see where the one to two minute applications could work, as I noticed some light spots happening right away with the first application. After rinsing it and trying it again, some spots were not comming off, especially around the fuel nipple where it would be harder to polish. I kinda gave up after that, thinking it would just need to soak longer....and thats when the blackening occured and I just went with it and ended up with what you see. I suppose if I were working with larger parts, and maybe a different color of anodizing (in this case - gold) it would be easier to see it work, and where more work was needed with the brush, and staying away from areas that were already stripped. I have bead blasted anodizing before and it DOES do a nice job of things, but in this case I wanted to stay away from that, as this was a "fuel" area and would be too hard to completely clean off the glass residue powder left behind, especially in the steel needle valve threads. A word of warning here that wasn't mentioned, is NEVER glass bead-blast INTERNAL areas of an aluminum motor...the glass "powders" itself into the aluminum, and no matter how clean you think you have rinsed it....it will continue to release itself into the motor, killing its life span. You can still do the outside, just make sure you tape off the all the openings (tapped holes also) before you bead blast with duct tape is all.
MI
Anderson Archery sells phosphoric acid for etching aluminum arrows so you can glue the feathers/vanes on. If you submerge an anodized aluminum arrow in it for more than a minute or two, the anodizing tends to disappear. The acid is a weak mixture and rinses off with water. Jim
