is there a good way to remove blind nuts?
KS
I am building a sig extra kit and I installed blind nuts for the engine mount that came with it but I was drilling the holes in it and it broke. I thought I'd use another mount I had lying around but it need new holes drilled in the firewall and new blind nuts. Any ideas on what to do?
My Feedback: (40)
NH
RE: is there a good way to remove blind nuts?
This comes up a lot with ARFs that have blindnuts pre-installed. I just thread the appropriate screw/bolt into the nut, knock it a few times with a small hammer, and the nut pops out with no damage anywhere. If you want to shift your engine mounting holes, I plug the wrong holes with a short length of dowel and CA it in place. Usually later on I will epoxy the surface of the firewall anyway. Drill your new holes, install your blindnuts in the right place, and move on.
BTW, if you have not installed blindnuts before, you drill a hole same size as the barrel of the blindnut. If your fuselage interior is too small to reach into, you can slip the blindnut onto a length of steel pushrod with a small ell at one end to hold the blindnut. Slip the pushrod into your firewall hole, pull the blindnut up to the hole, wiggle it around to coax the barrel of the blindnut into the hole. Slip out the pushrod, and get a piece of dowel or whatever to help hold the blindnut in place. Gently, thread the screw in from the front, engage the thread, turn it all the way tight and the screw will pull the blindnut into the hole, seating the teeth on the inside surface. Once it's well seated, I drip a little CA between the barrel and the firewall hole to help it stay put.
Banned
using a washer under the head of the screw while seating the blind nut ensures that the blind nut is being pulled into the wood and not the screw head
My Feedback: (24)
If the blind nuts have been epoxied in behind the firewall, heat up a soldering iron and insert it into each blind nut from the front of the firewall. After a few seconds, the blind nut will fall right out. I discovered this trick by accident one day.
My Feedback: (40)
NH
CA cures to a fairly brittle bond, as opposed to epoxy which will stretch a bit before it pops. Heat will soften the epoxy, but not have that much effect on CA. Sharp knocks on a screw threaded into the blind nut should pop them out with no problem.
My Feedback: (32)
AZ
ORIGINAL: Richard L.
(good idea! filed for future reference) [sm=thumbup.gif]
ORIGINAL: cwrr5
How in the world would you discover that by accident!?!?
when he was sleep walking one night, and thought he was playing with his wife. he pluged the soldering iron into "the hole", and by accident the nuts came loose
My Feedback: (15)
VA
just use a seeing eye screw............................i always get them out by what was said here screw the right size screw in and tap them out.
MB, CANADA
I usually just push them out of the plane ,but it really scares the HELL out of the dog,on the way down ...... DAVE B.
An excellent way to remove blind nuts without the hammer is shown on the following web page...
https://pinside.com/pinball/forum/to...uts-blind-nuts
Works a treat!
Works a treat!
