 Help installing Dubro skiis! >
Old 12-20-2005 | 04:06 PM
exeter_acres's Avatar
Default Help installing Dubro skiis!
My brain is just not working...
in the past I have made my own skis from plexi, but decided to pick up a pair of dubro skis at the LHS to put on my Katana...
for the life of me I can't figure out how the spring gets mounted????
the axle is just a bolt.... and I can mount it all fine, but I'm lost with the spring!
can someone explain it or post a closeup of the spring on Dubro skis... Please
Cheers
Exeter
Old 12-20-2005 | 04:25 PM
Default RE: Help installing Dubro skiis!
found a picture
http://www.dubro.com/DU-BRO/index.htm
got it figured out...
Man...sometimes the brain just stops... and won't restart![:@]
Old 12-21-2005 | 09:43 AM
I take it that you figured them out. Takes a moment, but after doing it once it's much easier. For the ease of just putting them on in a matter of minutes verses building a set of skis, -I love them. They work perfect on my super sportster, just the right size. My third winter on my only set, -should get some for my other planes. Let me know what you think of them after you try them out.
