Coloring Epoxy
I have been using Anchor Bond epoxy purchased through this site
http://www.anchorseal.com/products/abondprod.asp
150-Minute Epoxy Pump Kit
Packaged in 4.5 oz. bottles (9 oz. total) with metering pumps
Low odor, no Mercaptan
Standard dispense amount per stroke: 2 cc.
At the bottom are coloring agents. When I placed my order I got the set. I mix it really well with the resin [the coloring agent is a thick paste] then add the hardener.
Epoxy Coloring Dispersions - Colorset
• Packaged in 1 oz. Jars
• Color Set contains 1 oz. Each of Red, White, Blue, Yellow, and Black
• Simply add 1 to 3% (depending on desired color strength) to your epoxy mixture
FL
I am sure you could go to your local cake decorating supply store and get some coloring. They usually carry pastes and powders very strong stuff. a few dabs and can turn a whole cake blood red. That the stuff i used.
