 Try it You will LIKE IT >
Old 01-13-2006 | 06:40 PM
Live Wire's Avatar
Default Try it You will LIKE IT
Try wearing Latex gloves while building and when you are covering a plane. No stuck together fingers and you can not believe how you can control how you handle your project. Then see how easy it is to stretch your covering when you are trying to hold ont to that stuff
Never to old to learn
Old 01-13-2006 | 07:14 PM
Default RE: Try it You will LIKE IT
I better try it! Just peeled my finger from the wingtip of my piper cub. lost quite a bit of hide. Was just about to come up from basement with the wing stuck to my hand for some help. barely got it off!
Old 01-13-2006 | 08:23 PM
Blue_Moon_'s Avatar
Using latex gloves is also recomended when gluing with CA or epoxy, since its kinda dangerus to your health if you get the glue on your skin.
Old 01-13-2006 | 08:31 PM
Live Wire's Avatar
It was strickly an accident. My fingers are so raw from CA that I needed some thing to protect my thumbs because I was covering a plane and you can not believe how much it helps griping covering and holding on to a slick plane, and also protects your hand from fuel and cleaners.
Old 01-14-2006 | 09:03 AM
Campy's Avatar
Just be certain you do not have a latex allergy.
I use acetone at the end of the building session to remove the CA from my hands, then IMMEDIATELY after, thoroughly wash my hands. This removes the CA and minimizes my exposure to the acetone.
Old 01-14-2006 | 09:35 AM
Would also suggest applying a good coat of your wifes hand skin cream, rub it in good good. the Ca will peel off pretty good. will try the the glove solution also. dick
Old 01-14-2006 | 10:19 AM
Kmot's Avatar
My Feedback: (24)
Try "nitrile" gloves instead of latex. No allergic reactions to worry about. Plus, they do not swell up like latex does when expopsed to solvents.
Old 01-14-2006 | 01:01 PM
ORIGINAL: dicknadine
But not too much. You may end up getting some "rub off" on the balsa so that it will not stick EVER again. I like the glove idea. I would have thought that you would lose too much sensation wearing gloves. BUT you don't lose that much when wearing a "raincoat" either, do you
Old 01-15-2006 | 12:04 PM
Campy,
By the time the CA has dried, the damage is done! Better not to get it on your hands at all!
Old 01-15-2006 | 01:36 PM
flybug's Avatar
ORIGINAL: Kmot
Where do you get "nitrile" gloves from?
Old 01-15-2006 | 01:39 PM
David Cutler's Avatar
Excellent idea!
Two fetishes at once eh?
-David C.
Old 01-15-2006 | 11:00 PM
depfife's Avatar
My Feedback: (14)
http://www.eqplus.com/nitprotglov.html
If your local drug store or medical supply does not have nitrile gloves they should be able to order them. I know nothing about the business I linked to. It was just the first of several internet sources from a Google search.
ORIGINAL: flybug
Old 01-16-2006 | 10:30 AM
Mods-R-Me's Avatar
I did try it and I do like it!
Thanks for the tip
Mods
Old 01-16-2006 | 01:19 PM
Kmot's Avatar
My Feedback: (24)
ORIGINAL: flybug
Here is an online source:
Medium
Large
Extra Large
Old 02-07-2006 | 06:59 PM
Live Wire's Avatar
If you don't like gloves cut off the finger and use like a
