 Replacing a piston ring? >
Old 01-31-2006 | 06:47 PM
Default Replacing a piston ring?
Is there any advice on putting a ring on a piston? I had to order a new ring and piston for a basket case engine I bought used. I know these things are brittle. The enclosed image is what I'm fixing. Bought it as a "strong running engine"!
Old 01-31-2006 | 08:00 PM
tashley's Avatar
My Feedback: (9)
Default RE: Replacing a piston ring?
Set the piston down on your bench and take the ring with a thumbnail hooked on each ring end and gently slide it down over the piston crown and into the ring land. If your piston has a ring pin be sure and locate the ends of the ring on each side of it as you install it.
Old 03-24-2006 | 12:12 PM
coloradoz's Avatar
My Feedback: (38)
Try this link
http://www.mecoa.com/faq/rings/install/install.htm
..AJ
