Where do you get "phenolic" material?
I get my phenolic from a wood working store. They carry it to make templetes and jigs for power tools. Not cheap.
Have you tried trendlines, woodworkers, rockler, or any of the plastic distibutors in your city???
Dru.
Dru.
Just as a reminder!!!
Phenolic has asbestos in it. Material isn't dangerous unless you get dust out of it, then it's a problem. Make sure you were a respirator, or keep the Phenolic wet will you saw, sand, ect.... Asbestos isn't impossible to work with, just don't let it get into fine dusty airborne particles!!!!!
I donno about the circuit board, but true phenolic has the asbestos in it. It's really a big combination of meterials. Very good material for templates, and I see it used to make pump impellars on a regular basis, and when I machine the tolerances I always keep some water on it to eliminate the dust. Why take the chance??
OR
If you will look here....
http://www.tufnol.com/menu1_.htm
and here......
http://www.sdplastics.com/phenolic.html
you will see that the contents can be things other than asbestos.
Rolynn
and here......
Rolynn
My Feedback: (25)
Thanks for all your help guys. McMaster-Carr has something called "Garolite". It's a carbon fibre bassed product that should prove to be stronger then the Phenolic, and NO ASBESTOS. (yea)
-Mustang51
-Mustang51
My Feedback: (24)
GA
Phenolic is a solid laminate that is sold mostly through Laminate dealers, (Wilson Art) and is used a lot for toilet partitions. If you can find a company that sells the toilet partitions they will have scrap pieces. If you by it new it comes in 1/4 1/2 5/8 and 3/4" and cost from $9.00 to $12.00 sq ft. It has no asbestos in it.
If you live in the Atlanta area there is a company in Winder called Atlanta Sunbelt that has scrap pieces sometimes
The last time I bought any, (Carb spacers for a 3.7 twin), I got it from Boedecker Plastics, (Do a google search). Ordered it over the phone and they shipped to my door.
Steve
Puckett Model Aviation
Steve
