 top flite wire wheels >
Old 09-24-2006 | 06:53 PM
Default top flite wire wheels
Hello All
Question, since i have been in RC all my wheel have been plastic hubs and all control rods have been metal to plastic. This is to prevent static electric discharge that may cause radio interfearance. This is what i believe the reason was anyway. I am building a scale Pietenpol and have purchased Top Flite wheels when i was fiting them the light went on these have metal hubbs and landing gear is metal, the engine vibtation will cause static . Is this a problem with modern radio's or is this a problem from early RC radio's
Thanks for your input
Tom
Old 09-25-2006 | 11:22 AM
Default RE: top flite wire wheels
Hi!
Are you sure the wheels hubs are metal..? Very few if any are made of metal except some scale wheels.
Interference will be no problems with modern radios though.
Old 09-27-2006 | 06:14 AM
camdyson's Avatar
Tom,
Yes, they are metal hubs - at least my pair are. Metal-to-metal is still a no-no with modern radios too, and best avoided.
That said, I've used brass sleeved wheels on piano wire axles for years without problems. Have never heard of wheel/axle vibration causing interference, but I wonder if steel-on-steel may be tempting fate.
As an aside, I had a persistent "glitching" with my JR computer radio a few years ago, and traced it to the metal clip on my neck strap rubbing on the metal lug in the tranny. Silicone tube over the clip stopped the glitches. So, anything's possible!
Cam
Old 06-29-2008 | 03:49 PM
Broken Wings's Avatar
My Feedback: (20)
Tom, I've been looking at the Top Flite wheels as well as the Proctor wire wheels. How do you like them? Are the Top Flite wheels well made?
Old 06-29-2008 | 04:58 PM
Jetdesign's Avatar
My Feedback: (8)
What about a skinnier axle and a nylon bushing?
Old 07-01-2008 | 05:42 PM
KitBuilder's Avatar
Im told by very educated folks that metal to metal contact is not an issue with the 2.4 radios.... Metal to metal interferance resonates in a band much lower than the 2.4 ghz radios but it will affect the 72 mhz equipment.
Mike
