Spliting Cowls >
Spliting Cowls
Spliting Cowls
Old 01-16-2003 | 02:09 PM
Default Spliting Cowls
I have been asked how you would go about splitting a cowl and hinging it on top so will open in half. A fellow flier is going to install a twin in his plane ( guess its a CUB ) and asked how you do it. ANY SUGGESTIONS?
The DiBO :idea:
Old 01-16-2003 | 04:08 PM
staggerwing's Avatar
Default Cub Cowl
I did exactly this on my GP 40 Cub. I put a Saito .60 twin in it. I used a fiberglass cowl from Stan's Fiber Tech. I split the cowl at the centerline of the cylinders. Cut with a Dremel. I then epoxied small plywood tabs to the top half of the cowl at four places, two in from and two on back. I secure the cowl with #2 screws and washers through the cowl to the tabs. I can take the top of the cowl off to work on the engine. It looks and works great.
I think there was an article about doing exactly this in either MAN or RCM about three years ago.
Old 01-16-2003 | 05:41 PM
Default Winner
Now why didnt I think of that. Thanks alot
The DIBO
