Rebuilding a lite ply fuse >
Old 09-18-2002, 06:03 PM
Banned
Default Rebuilding a lite ply fuse
How bad is it?
If its a relatively clean break... double it inside with somehard balsa 1/4 inch triangular stock in all 4 corners, 2 inch lon pieces (one inch extension each side of break) and glue it all up with yellow glue, clamping firmly.
shouldn't need more than 1/2 oz noseweight to compensate.
If its like mine... fuselage kit. I shattered from LE to 6 in aft of TE.. LOTS of little toothpicks.
I hate going dead-stick when trying low level aerobatics... Vertical climb from touch-n-go and engine died just as I got into the vertical line. Appx 35 ft up... needed appx 45 to recover from the attitude... Not enough warning to kick rudder... it tailslid 1/2 the way down. Ugly.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
