Reload this Page >
Removing K&B Epoxy from fiberglass?????????
Old 06-05-2008, 01:12 PM
willey
My Feedback: (32)
willey's Avatar
Default Removing K&B Epoxy from fiberglass?????????
Question!! What are you guys using to remove K&B Epoxy (I'm pretty sure that is what it is) from a fiberglass fuse. I am in the process of rebuilding an old never flown Byron Staggerwing. I have tried three types of paint remover (aerosol can type from an automotive paint store) and nothing is touching it???
There is a new set of wings with that came with it so I'm building them instead of using the painted ones, so it is just the fuse I'm looking to remove the paint on.
Anybody have any ideas on this?? Thanks for your time!
willey
Old 06-05-2008, 01:15 PM
krossk
My Feedback: (27)
krossk's Avatar
Default RE: Removing K&B Epoxy from fiberglass?????????
Sandpaper and LOTS of elbow grease.
If it is K&B and it's fully cured, anything that will chemically remove the paint will also remove the fiberglass...
Old 06-05-2008, 01:21 PM
willey
My Feedback: (32)
willey's Avatar
For some reason I was thinking the same thing! guess I'll have to hit the gym for a while.
Old 06-05-2008, 03:19 PM
Gray Beard
My Feedback: (-1)
K&B is/was the same stuff as todays Klass Kote two part epoxy paint and once it sets up it's almost A forever deal. Think Powder Coating. Tough stuff, I tried to remove it with straight Acetone and A rag, it almost gave it A little dull to the finish.
Old 06-05-2008, 04:23 PM
MX240
MX240's Avatar
Removeing good ol'K&B Epoxy?
Good luck
That's why us old timers loved this stuff so much.
I still have two scale planes that I built in the early 80's and almost look like new yet.
Really... maybe try some stuff from a auto paint store called "gun cleaner" made by DuPont 3924S
This pretty strong stuff so wear rubber gloves....or you may be sterile for the rest of your life.
Old 06-06-2008, 03:03 AM
w5kfg
w5kfg's Avatar
Ihave removed old epoxy by using a covering iron with a sock on it. It will soften the epoxy and it can then be scraped or lifted off.
Bill
Old 06-06-2008, 07:10 AM
krossk
My Feedback: (27)
krossk's Avatar
The OP is referring to the 2 part, catalyzed epoxy paint - not the epoxy glue. The stuff is darned near bullet-proof when it's cured.
Old 06-08-2008, 07:46 AM
OldScaleGuy
OldScaleGuy's Avatar
How about just giving it a good sanding and repaint it with Klass Kote? You would not have to completely strip the old paint.
Old 06-08-2008, 08:04 AM
AA5BY
Yep, I recently refinished a fiberglass P-51 that had K&B epoxy on it and did lots of sanding and then repainted with Dupli Color acrylic enamel.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
