Grain Direction for rib strips
Hi,
Im buiding a 65% kaos out of the plans and the wing has these strips on top and bottom of the ribs. Similar to this picture i found on the net.
http://winshiprc.tripod.com/akro_ribs.jpg
From spar to leading edge the wing is sheeted and from spar to the trailing edge these strips are used.
What should be the grain direction of these strips?? I imagine that it would be parallel to the wing span (same as the sheeting) but i just want to make sure.
Also what are the advantages of having these strips? I am guessing that the covering will stick to these strips better than to bare sharp edged ribs. Is there any other advantage?
RE: Grain Direction for rib strips
Cap strips should have the grain run chord wise, not span wise. They add strength, and do give a better surface for finishing than the ribs on end do.
My Feedback: (9)
What you are refering to as rib strips are usually referred to as capstrips. The grain direction would be in the same direction as the rib. The capstrip us usually 3/8" to 1/2" wide and the same thickness as the leading edge / trailing edge sheeting. Use a balsa stripper or a straight edge to cut strips off a of sheet or scraps of the proper thickness. Capstrips provide tremendous strength to ribs in addition to adding attachment area for the covering. A 65% Kaos should be an awsume flyer. Please keep us posted on the results.
zx32tt
zx32tt
Thanks for the quÅŸck replies. I will try to take some pics of the wing tonight and post it.
In case you may be interested the plans are free on this link.
http://plans.rcmodell.hu/planelect.html
65% Kaos?? Glow version is 55"... I assume your building the electric version at 38". I'm just curious.. where does the 65% come in... doh! just realized.. ... 65% of the original. I'm used to it going the other way, larger.
Mike
Mike
