satio 72 4c high & low settings now off
Frank, All is explaned [link=http://saito-engines.info/throttle_setup.html]HERE[/link], just follow the instructions on the site and you will have a sweet running Satio.
Cheers
Cheers
My Feedback: (13)
NJ
I have found that a good starting point for the low end needle is to lean it until the engine wont start. At that point, richen the low end 1/2 turn. Them do minor adjustments on the low end from there. Has worked well for me.
If it wont run at all, maybe check your plug. Make sure you are pulling fuel along the line into the carb.
