A VERY GOOD TIP YOU CAN USE !!!
SC
Hello all,
After removing monokote from the airframe, you may end up with some adhesive or tags of covering behind. A super fast way to remove this is to use ULTRACOTE (not MK) and iron a section over the area. Then peel off this layer right after. You will end up with a fresh CLEAN area that are ready to go. This beats the old fashion way of trying to pick these off with Xacto blades. DP
SC
RE: A VERY GOOD TIP YOU CAN USE !!!
ORIGINAL: GarySS
Kind of expensive to use pricy Ultracote, but this gives a reason to save any scraps in a box for future ''striping''.
My Feedback: (9)
ORIGINAL: p100d
Just rub with Acetone on a rag and it all comes clean. Cheap and easy.
