 Razor saw blades without the frame? >
Old 06-19-2010 | 11:51 AM
dave_anderson's Avatar
My Feedback: (47)
Default Razor saw blades without the frame?
Do any of you know where I could get some razor saw blades that do not have the thick frame piece along the top? Just a flat blade. I think it would be useful to cut flight controls from foam wings.
Old 06-19-2010 | 12:02 PM
Default RE: Razor saw blades without the frame?
consider a Flush Cut Saw like this one from Harbor Freight [link=http://www.harborfreight.com/japanese-flush-cut-saw-39273.html]Japanese Flush Cut Saw[/link]
Old 06-19-2010 | 12:07 PM
wattmeter's Avatar
ORIGINAL: dave_anderson
What may work is a flush cut saw like this http://www.nextag.com/Shark-10-2204-...82C58DB9D9DD63
wattmeter
Old 06-19-2010 | 01:55 PM
My Feedback: (47)
Now we are gettin close. I wish they showed the thickness of the blade.
Old 06-19-2010 | 01:56 PM
Here are some choices:
http://www3.towerhobbies.com/cgi-bin...&I=LXXRP3&P=SM
http://www3.towerhobbies.com/cgi-bin...&I=LXLH63&P=SM
Bruce
Old 06-19-2010 | 03:04 PM
My Feedback: (9)
Micro-mark has a saw #82985 made by Zona ,16 teeth per inch & .012 thick . Blade is 6 1/2" long by 1 1/4" deep . Comes with a handle. Latest catalog shows it at $8.50 on sale . Good luck , Max H.
Old 06-19-2010 | 04:04 PM
I have removed the stiff back from a Zona saw leaving a nice flat flexible blade for use where only such a blade can be used. It is not to hard to pry the stiffener off.
Old 06-19-2010 | 05:26 PM
Live Wire's Avatar
How about going to a hardware store and getting your self a HACK SAW BLADE
Old 06-19-2010 | 05:47 PM
http://www3.towerhobbies.com/cgi-bin...&I=LXKY31&P=SM ??????
Old 06-19-2010 | 07:36 PM
My Feedback: (47)
Great ideas fellas thanks
Old 06-28-2010 | 10:20 PM
My Feedback: (7)
If you're still trying to source these blades, ask for Xacto #15 keyhole saw blades. They are 2 1/2' long and fit into type c and d Xacto handles. VERY HANDY, and cheap too, about 6 dollars for a pkg. of 5. I use them all the time. Lowes Hardware and Sears carry them.
Old 06-28-2010 | 10:38 PM
vertical grimmace's Avatar
I have a Zona saw without a back. I love that thing. I use it for everything. The Japanese style teeth are wonderful. This is the tool fo cutting ailerons free from your wing.
Old 06-29-2010 | 09:25 AM
If you ever compare the Xacto blade with the Zona blade, you will trash all your Xacto blades. The Zona's cut so much better you won't believe it.
