How to remove old vinyl graphics
Hey, is there a way to remove and reuse old vinyl graphics with out ruining them? Thanks, John
RE: How to remove old vinyl graphics
John.
Even if you could get them off without ruining the decal, all the adhesive would likely be gone. If you would like to replace the vinbyl graphics. I am sure we can help you with that at [link=http://www.getstencils.com]GetStencils.com[/link] Generally speaking vinyl decals are not very expensive. Jerry |
ORIGINAL: quietstorm366 Hey, is there a way to remove and reuse old vinyl graphics with out ruining them? Thanks, John The tricky part is putting them back down. 3M 77 spray contact cement works pretty good I agree with Jerry, generally it not worth the trouble, but I've done it a couple times with decent results with hard/impossible to get Graphics for my Dirt Bike. |
I make model graphicxs. Most don't know this. :D
Only thing I would use is a bit of light heat from a heat gun. The florida sun is also helpful. I've removed vinyl lettering from trucks that was years old using just the sun's heat. There will be some adheasive to remove after the vinyl is removed. I use professional stuff for this. You can buy a product made by the 3M company that is designed to remove the adhesive. Body shop supply places carry 3M products. Although I have never used this, I'm told lighter fluid works also? Patients are important. Let us know how you make out? Charles |
I prefer Xylol (Xylene) for removing most sticky residues. BIG CAVEAT: make sure you wear nitrile gloves and only use it in a well ventilated area. This stuff is nasty. You can find it in most home stores in the paint aisle. I use it to remove the monokote adhesive that remains after I've removed as much as I can by peeling and peeling while applying heat. Takes it right down to the wood. Works alot like Ironex.
ORIGINAL: Avaiojet I make model graphicxs. Most don't know this. :D Now that I think about it I'm pretty sure you've mentioned it once before :) To the OP, get them re-cut, if you want take a high res picture before you take them, most graphics shops can usually duplicate them. Cost depends of course on complexity. I use Goo Gone from Walmart, followed by alcohol to remove the adhesive residue. |
any updates? what is easiest way to remove vinyl decals from a painted cowl?
If they aren't clear coated, just use your fingernail to lift the edge and peel it off then goo-gone for the glue, follow that with alcohol to remove any residue.
Originally Posted by BarracudaHockey
(Post 12389551)
| All times are GMT -8. The time now is 01:32 AM. |
