APC Prop Painting
Has anyone used that FUSION paint on an APC prop?
How did it work? Just wondering as a black prop loooks so much nicer on a warbird than a grey one!! Thanks Mike |
RE: APC Prop Painting
Mike, paint is not going to stick to the plastic. Guys have been having good success using Rit dye and dying them black.
I saw that somewhere! Does it do anything to the integrity of the prop?
Not that I am aware of. Some of the warbird racing guys I fly with dye their props. These airplanes hit 150-160 MPH
Hey that sounds interesting,and you can then paint the tips white or?:)
Hi!
2 part acrylic car paint hold up fairly well on APC props. |
1 Attachment(s)
ORIGINAL: YAT-28E Has anyone used that FUSION paint on an APC prop? How did it work? Just wondering as a black prop loooks so much nicer on a warbird than a grey one!! Thanks Mike I've been painting my APC props for years, and have never EVER had any problem at all. After balancing the prop, I lightly roughen up the surface with fine sandpaper, and clean it thoroughly. Then I prime it with rustoleum primer, and spray paint it with Rustoleum. I nearly always paint the tips, often with various colored stripes, to dress it up. With warbirds, I use black, and always paint the tips either white or yellow. When done, I re-balance, brushing a little paint on the tip to get a fine balance. I've never had paint chip off of one of my props. Mike |
ORIGINAL: speedracerntrixie Mike, paint is not going to stick to the plastic. Guys have been having good success using Rit dye and dying them black. |
Sounds expensive LOL I have painted CF and wood props but because injection molded plastics have mold release in the plastic fomulation I wouldn't have thought paint would stick well. Glad some guys are having good results. I'ts details like this that turn a good model into a great one.
| All times are GMT -8. The time now is 07:49 AM. |
