MonoKote will not shrink
I purchased a 25' roll of Transparent Red MonoKote and started covering a Sig Kadet model of mine. I tack the edges of the material down and when I used a heat gun to shrink the material it just appeared to loosen up with many more wrinkles than I started with.
I have never had this happen before. Has anyone else had a problem similar problem with shrink material? |
RE: MonoKote will not shrink
Yes, the new Monokote does not shrink like the old stuff did. What you need to do is pull it as tight as you can while tacking it down so that you only need a small amout of shrinkage to tighten it up. It also requires more heat then it used to.
ORIGINAL: DVI I purchased a 25' roll of Transparent Red MonoKote and started covering a Sig Kadet model of mine. I tack the edges of the material down and when I used a heat gun to shrink the material it just appeared to loosen up with many more wrinkles than I started with. I have never had this happen before. Has anyone else had a problem similar problem with shrink material? One of the builders at one of the flying fields I go to who built and covered many, many very nice planes had used MK for years, and he stopped using it completely a few years back. I remember him stating just how bad the last MK he used was. Some folks are still getting good MK. I must be on the list who got the bad quality MK. |
ORIGINAL: DVI I purchased a 25' roll of Transparent Red MonoKote and started covering a Sig Kadet model of mine. I tack the edges of the material down and when I used a heat gun to shrink the material it just appeared to loosen up with many more wrinkles than I started with. I have never had this happen before. Has anyone else had a problem similar problem with shrink material? Sometimes with film covering, it takes what it takes... as there are variables that come into play, such as environment(we are dealing with heat-sensitive material), the structure being covered(open bay or solid), even down to the tools being used... and I'm not saying anybody else is wrong, or that I'm right here.. but these are all possibilities you might consider.. I wish you well. :) |
Alot of the flyers at my club have convinced me that there is a GRAIN in the monokote, it's not always easy to see but it appears to be true. I had better results with pulling it and tacking as tight as possible. ( working with the grain )
And yes MK is not what it used to be. Ultra Kote worked better at lower heat on my last plane. Moving to Solartex next time. |
The new Monokote is expensive junk. It will not shrink aat all. If you do put heat to it, it just wrinkles, and burns. The sad part is TopFlite won't acknoweledge they have a problem, but rather try to blame the end user for unsatisfactory results.
Top flight is owned by Great Pain. Direct your displeasure over the product to them. Not that they will answer you or even give a dam but you can try. After 45 years of using the stuff I've had it and have moved to Ultrakote.
They have killed Coverite, Monokote, most of the kit makers and everything else that they ever got their hands on. Perhaps that is why most of their stuff is little more then toys at rediculous prices anymore. Dennis |
About 5 yrs ago they changed the formula for the monocote and hasn't worked right since. Try the stuff from HobbyKing. Works every bit as good as Ultracote. Seals and shrinks at low temp. I just covered a Byron 1/3 scale Christen Eagle right on the foam and it turned out great.
Makes me glad I bought that big lot of, what, 40 rolls? or was it 80? of monokote of ebay several years ago.
Go Ultra! Mono tends to stink now. JMHO
Pete |
Solortex is the best. For me Mk was always a pain to work with. 21st Century is good and the Tex. Haven`t covered anything in years, I mostly paint now but I still have a few iron on covered planes. A few years ago I did the rudder of my H9 T6 and used Tex to cover it back. It was as easy as ever with all the curves. Don`t know why people still use that MK stuff, its the worst. The 21st Century was far better, much stronger and easier to work with.
ORIGINAL: 91zulu Solortex is the best. For me Mk was always a pain to work with. 21st Century is good and the Tex. Haven`t covered anything in years, I mostly paint now but I still have a few iron on covered planes. A few years ago I did the rudder of my H9 T6 and used Tex to cover it back. It was as easy as ever with all the curves. Don`t know why people still use that MK stuff, its the worst. The 21st Century was far better, much stronger and easier to work with. Yes I think Solartex rules when it comes to heat shrink. Love the stuff and to me worth the money. But anything that isn't scale I'd use Ultra. Haven't tried 21st Century yet so I can't comment on it. Pete |
ORIGINAL: speedracerntrixie Yes, the new Monokote does not shrink like the old stuff did. What you need to do is pull it as tight as you can while tacking it down so that you only need a small amout of shrinkage to tighten it up. It also requires more heat then it used to. |
I'm smiling - I've only used Ultracote - only been building a couple of years. Why am I smiling? If a builder has used Monokote over the years they spell it Ultrakote. ;)
AlwaysBring2 made a grain comment. Ultracote has a noticeable grain (orange peel) too. There are 3 temps for Ultracote - (1) initiate adhesive, (2) full adhesive / start stretching and (3) shrinking. These are my terms only. The grain disappears between (2) and (3). The 3 temps are easily managed with an iron (not exactly sure). I don't use a gun to shrink. But what got may attention - DVI said that his film stretched but didn't then shrink. Seems that Monokote goes thru the same 3 phases - just that shrinking takes a heck of a lot of heat - near "burning / melting" heat - to get it to shrink. |
Have been using monokote for awhile now. I agree that it seems to take more heat than earlier stuff but I still get good results from it. It seems to be stronger than Ultracote
and once tightened it seem to wrinkle less when in the sun. I get the best results using a iron and forgetting about the heat gun. Monokote does not appear to be as transparent as Ultracote which I like.Maybe some who have had trouble with it just aren't applying enough heat. |
I have some rolls of MoneyKote that are 20+ years old, and some new rolls a couple of years old... There is a difference in workability, and it's not for the better. [:o]
Last time I used MonoKote was 8 years ago, and got good results. Was it an EPA thing that caused them to change it? Or was it a PROFIT thing?? With Great Planes, I'd bet it was the latter. [X(]
Tried 21st Century fabric this year, hated it so much that I learned to use the fabric-and-dope method instead. Will probably never stray from it, as my results were astonishingly good! I even changed my RCU handle, I liked it so much. :D |
1 Attachment(s)
I mainly use Monokote and have had good results, but I also I have used Ultracote with good results. Ultracote is definitely more forgiving and easier to work with were as Monokote takes more time and technique to apply. The advantages of Monokote are the seams don't pull, the seams are not as noticeable, Monokote is more opaque, and Monokote just has a nicer look. Ultracote is much faster to apply, I would say it takes twice as long to apply Monokote vs Ultracote. Monokote requires heating, shrinking and pulling for a tight wrinkle free finish. Utlracote just requires you to put it on then shrink nice and tight. I just finished my Herr Pt-17 with Monokote and the fuselage was covered with only 2 pieces of Monokote but it took a lot of stretching and pulling. The wings are covered with one piece of Monokote on the bottom and one piece on top. Monokote is a great product but it is a shame that Top Flite will not address its customers complaints. I know that most builders I fly with are using Ultracote and my LHS are carrying less and less Monokote and more Ultracote. I like the ability to just drive down to my LHS to buy covering, so if they get rid of Monokote, I might have to switch over to Ultracote.
I wonder how the builders of Great Planes ARFs apply their Monokote? The Great Planes ARF's I have seen look great. |
I keep wondering how long it will be before TopFlite, Great Pains or whomever owns Monocote now, to see a big enough finaicial loss via lost sales to admit they have a problem. I also can't help but think companies like Hobbico monitor forums like this and RCU in general. I guess the silver lining to the monokote mess is I have learned to 'glass and paint my planes.
I think we make up such a small amount of business for Monokote that it does not matter.
Hmm... interesting thread.
My favorite covering material used to be Coverite 21st Century fil, but I am convinced it has changed and become Black Baron (note the much lower working temps of the new rolls of 21st Century). And now I read that Monokote now seemingly "won't shrink"... which was the complaint about the old 21st Century film. The 21st Century film WOULD shrink... it just took a longer exposure time to heat. Wonder if the goofballs at Hobbico/Great Planes/Tower have pulled a switcheroo and lack the integrity to inform us? After being absent from the hobby for 7 years, seems like the Hobbico/Great Planes/Tower marriages has gone down the tubes tremendously in the meantime. |
| All times are GMT -8. The time now is 03:04 AM. |
