RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   A clever way to store your airplanes! (https://www.rcuniverse.com/forum/tips-techniques-180/10775033-clever-way-store-your-airplanes.html)
Kostas1 10-20-2011 01:59 PM
1 Attachment(s)
I just finished the job.....The aircraft is the Greatplanes Giant SuperSportster ARF@Saito FA-180GK!
Regards...
http://s.myniceprofile.com/myspacepic/152/15225.gif
tail strike 10-20-2011 02:08 PM
RE: A clever way to store your airplanes!
What does your wife think of those planes hanging over the bed :)
Kostas1 10-20-2011 02:33 PM
Hahaa i am only 25 ;)
tail strike 10-20-2011 02:35 PM
ORIGINAL: Kostas1
What does your Dad think of those holes in the cealing :)
Kostas1 10-20-2011 03:06 PM
He is like....http://findicons.com/files/icons/203...e_creature.png
No, seriously...it's the best way to avoid any hangar rush!!!!
foodstick 10-20-2011 03:20 PM
I have a good story for you . A friend of mine is a divorced and single type... he has a pretty unfinished house, and a girlfriend that is not quite running the show like she would like to.. One day he mentioned to her he was out of room for airplanes..and he told her he might hang one in the living room overhead.. she said "There is no way you are hanging an airplane in the living room !"
Well it didn't sit well with him, and he hung about four airplanes in the living room ! .. Every time i am over there I bump my head on some landing gear ! hahahah
Once in awhile he has to stop and jam a new paper towel into an exhaust so it will quit dripping :D
Kostas1 10-20-2011 03:44 PM
Hahhaaahaaa awesome!
But how wifey agreed on the living room crusade;;;;;
biam 10-20-2011 03:50 PM
Looks like the same method I use to store mine in the off season, only in the finished basement. I also hang mine with the wings attached.
blikseme300 10-20-2011 04:07 PM
Wife ver 2.0 told me to choose between her and my aircraft. I now have wife ver 3.0
Bliksem
Kostas1 10-20-2011 09:37 PM
ver. 3.0 ;
OMG....http://icons.iconarchive.com/icons/a...2/omg-icon.png
Villa 10-21-2011 06:00 AM
Hello Kostas1
In one of your photographs you show a light bulb hanging from the electric wire from the ceiling, next to your plane. When I was in Germany on a visit I saw the same thing and learned that the electric current to the bulb was 230 volts. In the United States our current is only 110 volts in the same application. As a result I have always been afraid of 230 volts. The electric frequency in Germany was also 50 cycles, and ours is 60 cycles. What is the current and cycles in Greece? I know that 230 volts is more efficient since smaller wire can be used. Just curious. No problem. I like your idea of hanging the planes from the ceiling. I store mine on an empty bed. I always put paper towel in the exhaust pipe and wrap a small towel around the engine to catch dripping fuel. Fuel will drip from the front of the engine because there is no seal there.
Kostas1 10-21-2011 09:17 AM
Hi there!
Yes....the current that the National Electricity Company provides is at 220-240V@50Hz.
KitBuilder 10-21-2011 12:25 PM
ORIGINAL: Kostas1
whats up with the sheets ????
rgburrill 10-21-2011 01:02 PM
And yet - When I finished my Corsair my wife said to hang it in the living room because it look beautiful ;<)
Bob
ORIGINAL: foodstick
eagledancer 10-21-2011 02:46 PM
ORIGINAL: blikseme300
Bliksem
wife ver 2.0 and ver 3.0 said that, i am now on ver 4.0 and this one loves my airplanes and i have permission to hang them anywhere i want!! sometimes change is a great thing
Kostas1 10-21-2011 09:10 PM
Also being lucky helps a lot!
91zulu 10-23-2011 03:07 AM
Sure is . You know how hard it is to find a woman that will tolerate us and our hobby. You stand a better chance finding a unicorn . :D
Kostas1 10-23-2011 03:25 AM
So true.....
Goran619 10-23-2011 08:27 AM
This is how I hang my planes in my garage but I use bicycle hooks and small rope. As for the wife thing my wife excepts it(she is even the one that told me to order my first plane) but she does not like it one but. She feels I spend <font color="#ff0000"><u>WAY </u></font><font color="#000000">to much money on it and she proeeds to yell at me :(. Just wait till she finds out I'm ordering the landing gear to one of my planes and I am in the process of buying a discontinued TF kit :D.
Jordan</font></p>
rye 10-23-2011 11:31 AM
[:@] duck!!!!!!!!!!!!!!!!!!!!!
rye 10-23-2011 11:34 AM
hi
i hang them by the tail on the wall is that bad for the motor? i use a heavy duty cloth hanger with foam tubing ,thanks
Kostas1 10-23-2011 11:28 PM
Nice idea, that i thought of it prior to deciding what technique fits me best.
It is a good idea but i didn't have that much space on my walls in my room to do it.
I am also thinking if this way of storing your fuselage affects the fuel pick-up tube inside the fuel tank. http://www.basic256.org/media/purzen...on_mark_30.png
AA5BY 10-24-2011 06:51 AM
Kostas, in your pictures above are illustrated some small lag hooks and plastic anchors. I've a question as to whether you used the plastic anchors in sheet rock and inserted the hooks into the plastic anchors or did you screw the lag hooks into ceiling joist?
What I'm suggesting is that those plastic anchors are designed for moderate lateral loads, ie something hanging from a wall at a 90 deg angle to the anchor. Your loads will be in the moderate range but are straight loads. Used as such, the plastic anchors are probably only good for light loads.
Kostas1 10-24-2011 07:48 AM
Will you please explain me a little bit your post;
There are 3 hooks that share a 5kg weight...
The procedure was:
Fristly drill the hole, then insert the plastic portions and hammer them to get a snug fit....
Then start screwing the hooks that will eventually force the plastic portions to expand inside the concrete.
AA5BY 10-24-2011 08:14 AM
If the ceiling is concrete, rather than sheet rock then the fasteners will produce much greater resistance to straight on loads and will likely serve as a suitable anchor.
Concrete ceilings are not the norm in the US, as sheet rock is more often the material. It is a composed of a product called gypsum between two layers of paper and is of medium density and strength and unsuitable for such anchors for straight on loading.
