RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Removing monokote trim from monokote (https://www.rcuniverse.com/forum/tips-techniques-180/10829991-removing-monokote-trim-monokote.html)
lleach1 11-26-2011 12:34 PM
I have been removing trim Monokote or Iron-On Monokote used as trim over Monokote. In some cases the clear outer layer comes off but the pigment and adhesive remains on the Monokote surface. What is the best method or product for removing this pigment and adhesive ? Thanks
mikegordon10 11-26-2011 01:31 PM
RE: Removing monokote trim from monokote
Monocoat Trim Solvent, Acetone, MEK etc.
Oberst 11-26-2011 03:40 PM
ORIGINAL: mikegordon10
That's what I do.
Pete
DavidAgar 11-26-2011 04:17 PM
Monokote Trim Solvent will get it right off.....Good Luck, Dave
DustBen 11-27-2011 07:05 AM
Almost any petroleum based solvent will work.
I keep a can of charcoal lighter fluid in my chemicals. It's cheap, less likely to attack any plastics or finishes and stays "wet" longer than mek.
If charcoal lighter fluid won't work, then I use something a little "hotter" like lacquer thinner, and then acetone, and so on.
Keep the charcoal lighter fluid handy when covering... while mek or acetone will clean the smudged backing off the iron, the charcoal lighter fluid won't evaporate off the hot surface so quickly. Furthermore, using mek or acetone will remove some of the coating off the iron surface in time whereas the charcoal lighter fluid won't.
WaffleMan 01-14-2012 05:29 PM
Just put a patch over the darn thing!
