RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Shopmade bellcrank (https://www.rcuniverse.com/forum/tips-techniques-180/10849528-shopmade-bellcrank.html)
grosbeak 12-08-2011 06:41 AM
Shopmade bellcrank
I wanted a bellcrank for the choke on the DLE 20 I'm putting into my Pulse 125. I know light-duty bellcranks are cheap - heck, you can get two from Du-Bro for $1.69 at the LHS. I did this a challenge to see it I could.
The parts: A spare bolt, washers and nut, an unused Hitec servo arm (clipped, shaved, rounded and reamed) and two support arms cut out of plywood reclaimed from an empty clementine crate.
http://farm8.staticflickr.com/7145/6...69fd2b3d_z.jpg
I drilled the holes in the wood with the pieces clamped to a back board, stepping up two drill bit sizes each time. After drilling I wicked some CA into the wood around the holes on both faces of each piece, then I pressed the washers into the wood with a vise. Put together:
http://farm8.staticflickr.com/7166/6...1aa6c7e4_z.jpg
The intent is to mount it on the back of the firewall. The last step was to add a backing plate for (a) extra spacing and (b) ease of attachment. It'll go about here:
http://farm8.staticflickr.com/7006/6...07cd46c8_z.jpg
I don't know that it would stand up to repeated use with a control surface but it ought to work just fine for the choke.
There you have it. This airplane may be an ARF, but this mini-project was definitely a build. ;)
MinnFlyer 12-08-2011 06:51 AM
RE: Shopmade bellcrank
http://www.minnartist.com/RCU/grafix/Thumbsup.jpg
JRFisher 12-08-2011 08:41 AM
And I thought I was the only one using old clementine crates.
cutaway 12-08-2011 05:03 PM
FWIW, Old DC2180 QIC computer backup tape cartridges contain a nice piece of aluminum that's good for fabing stuff like this.
ARUP 12-09-2011 06:45 AM
ORIGINAL: JRFisher
Great lite ply!!! I'm a frugal cuss, too. ...and good job on the homemade bellcrank!
