RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Help....Warped elevator (https://www.rcuniverse.com/forum/tips-techniques-180/11024312-help-warped-elevator.html)
flybyme 04-01-2012 05:45 PM
1 Attachment(s)
How can i fix what seems to be a warped elelvator. The right side is flush, while the left side is off center. Fresh out of the box.
Redback 04-01-2012 06:19 PM
RE: Help....Warped elevator
Can't see from the pix what the elevator joiner looks like.
If it's wire and you can get to it should be fairly simple to (carefully) bend it until the two sides are level. Hold one end in a vice and carefully twist the other end round with pliers. Will usually take a couple of goes to get right, little at a time is the way to go.
Terry
daveopam 04-01-2012 06:23 PM
It's not the wire, the right elev half is twisted. Is that a foamy? Or is it built up and covered/painted?
David
flybyme 04-01-2012 06:50 PM
it's buit up and covered....is there a quick fix?
42etus 04-01-2012 10:01 PM
You could try heating the covering to pull some of the warp out, but judging from the severity of the warp, I don't think it'd work. I don't see a quick fix. If it were my plane, I'd:
1. Return it to where I got it
2. Build a new (straight) elevator from scratch
YMMV and others may have better suggestions
MinnFlyer 04-02-2012 05:57 AM
I think it looks fixable, but you might need two sets of hands.
have one person hold the elevator and twist it the other way (wearing gloves) while the other person applies a heat gun to the top and bottom
j.duncker 04-02-2012 07:01 AM
IMHO any twist and heat gun fix will be pretty temporary.
Ask the mf for a new elevator.
OR strip the covering off, seperate the joints pin flat and reglue then recover.
MinnFlyer 04-02-2012 07:03 AM
These things are jig-built, so more often than not, the warp was caused by the covering to begin with and re-heating should fix it.
flybyme 04-02-2012 09:39 AM
Then re-heating with four hands should do the trick.......thanks a bunch guys.
flybyme 04-02-2012 10:17 AM
Now this is what I call great Customer Service. I sent notice to Top Flite informing them of the warped elevator. The first response I received from them was that they had verifed my purchase from Tower, and that my replacement tail surfaces were on the way. Yeaaahhhhhhhhhh Baaaaabyyyyyyyy
j.duncker 04-02-2012 02:43 PM
ORIGINAL: flybyme
RESULT
KitBuilder 04-02-2012 03:32 PM
How are they attached.. CA hinges?
flybyme 04-04-2012 09:45 AM
Yes
KitBuilder 04-04-2012 04:37 PM
So you'll need to be cutting the originals and making new slots, etc. have you installed CA hinges before? I'm not sure if where there are located now there is some wood backing. They'll have to be reinstalled a bit left or right of the oringnals whch may have no add'l wood for the hinge as backing.
flybyme 04-04-2012 06:58 PM
Yep, have installed many before, they weren't glued in yet......the warp was discovered in the dry fitting. Looking for delivery of the new ones tomorrow, I hope.
flybyme 04-05-2012 07:57 AM
Hmmmm, I received my new elevator today, and I got the same result....so I twisted the wire a bit, same result. Next I guess I'll try the four hands heat and twist, and if that doesn't work, the rebuild of the left elevator. I guess. Bummer....but I'll not give up, something has to work.
flybyme 04-05-2012 10:47 AM
Hooooraaaay, worked like a charm, the four hand heat and twist method worked. You guys are great......Thanks
daveopam 04-05-2012 02:12 PM
That's great, just keep an eye on it for the first few flights. Sometimes they will twist back a little. Normally you have to twist them past the straight point so when they bounce back they are straight. So if your trim starts to change in flight, land and check it out.
david
MinnFlyer 04-06-2012 06:12 AM
WadidItellya? :D
daveopam 04-06-2012 01:34 PM
You da man Minn!
David
