FMP Fox
My EPO foamie Glider arrived with a big triangular notch out of the rudder. What's the best way to fix this? I'm a balsa and monokote man with no experience with foam.[:@]
RE: FMP Fox
If you have the piece, then some foam safe zap, epoxy, white glue, or other foam safe glue.
If not, find a sheet of dollar tree foam and then fill it in and sand it. Buzz. |
RE: FMP Fox
Use some super light weight spackle from your local hardware store or Home depot for a small hole.
| All times are GMT -8. The time now is 01:11 AM. |
