Stix-It Question
When one side of a wing is covered using Stix-It and Koverall, do you brush a coat of it over the edge of the covering so that the overlap will adhere to the layer underneath it?
Chuck |
RE: Stix-It Question
Right! Treat it as if it were bare wood. Max H. :)
And... if you want a really nice fabric join then lay down some masking tape first. Pull fabric over the overlap and 'stiple' the Stix-It through the fabric and up to or slightly over the masking tape. Once it 'cures' use a very sharp knife to cut the excess fabric. Works a champ with nice straight fabric overlap and no fuzzies!
Thanks for the suggestion. What technique do you use for cutting the straight line?
Chuck |
| All times are GMT -8. The time now is 04:29 PM. |
