ULTRACOTE
HOW DOES ULTRACOAT SILVER APPLY?? PAIN OR EASY?? DO SEEMS HIDE GOOD??
RE: ULTRACOTE
1 Attachment(s)
it goes on the same as the other colors ,does it show lines? yes more then the other colors but if you lay it out right you can hide the seam at bottom or if you sre going to use strips of a diffenet color or tirm ,heres a p-51 gaint i did a few years ago
RE: ULTRACOTE
I have found all silver coverings to be the hardest to work with. The adhesive seems to be a bit more rubbery and too much heat quickly pulls it away from the seam - more so than the standard colors. But if you need/want silver...then silver it is.
Kurt |
RE: ULTRACOTE
:D:D:D THANKS FOR HEADS UP..
| All times are GMT -8. The time now is 07:26 PM. |
