RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   best way to clean a gumed up nitro carb (https://www.rcuniverse.com/forum/tips-techniques-180/11622486-best-way-clean-gumed-up-nitro-carb.html)
mrbee 10-07-2015 04:58 AM
i have a nitro carb that has been sitting and now its stuck, whats the easyest way to clean so it will move, please help, thanks for your time
crazyflyer92 10-07-2015 05:44 AM
Heat is the best way for me a soldering iron to the carb
mrbee 10-07-2015 09:15 AM
that iron was the way to go thanks crazyflyer92:D
crazyflyer92 10-07-2015 10:59 AM
glad I could help you!
dasquirrelisme 10-07-2015 02:46 PM
You can also soak the carb in a jar of glow fuel. Just remove the O-rings first. That's only if the heat wont work. Sometimes just a drop of fuel in the throat loosens it also.
jayd3 10-09-2015 03:46 PM
I use a heat gun and give it a lubing with 0-20 motor oil or any good quality light oil, this works well for carbs and engines.
From experience I can tell you do not leave it soak in pure alcohol for very long or it will corrode.
Jayd
