RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   3 part wings (https://www.rcuniverse.com/forum/tips-techniques-180/11629542-3-part-wings.html)
bentley1$ 05-17-2016 03:43 PM
3 part wings
I am building a giant ugly stick (100" WS) from plans. The center section will be permanently attached and extend about 4-6" past the starboard and port sides.
Do I need to worry about wing separation when using alignment tubes, or is there a way to lock the wings in place.
Thanks for any assistance,
RBACONS 05-17-2016 04:12 PM
Absolutely. Simplest way is way is to plug the last inch or so of each end of the tube with a hardwood dowel of the correct diameter, install a hardwood block in the wing just above or below the tube end, assemble the wing and drill/tap through both hardwood blocks, disassemble, harden the threads with thin CA, and then install an allen head bolt when assembling the plane.
For another option, check out the "Merlyn Wing Lock" tutorial on RCSCALEBUILDER.
I use a spring-loaded latch that captures a hidden bolt head but its a bit involved to explain here. No bolts to install/lose and just a 1/4" stub of music wire exposed under the wing.
bentley1$ 05-17-2016 04:47 PM
