RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Simulated Hinges (https://www.rcuniverse.com/forum/tips-techniques-180/11642842-simulated-hinges.html)
redtail 11-08-2017 05:33 PM
Simulated Hinges
Hey Guys,
When metal piano hinges are too large, how do you simulate a hinge on small hatches or latches? Thanks. Chic
ziggy138 11-12-2017 09:07 AM
simulated hinges
You can simulate hinges bu using small dia. alum. tubing. Cut into small pieces and run wire thru center. You must glue every other tube to same surface on one side, then glue the other tubes to opposite surface. Do this very carefully and you will have a scale hinge that works also. Just use wire to keep it all lined up, and keep wire lubed also so you do not glue it in place.
redtail 11-12-2017 09:28 AM
Another great idea. Thank You. Chic
OldScaleGuy 11-16-2017 03:57 AM
I use aluminum tubing too of the appropriate diameter, then roll it with a #11 blade to score the tubing at the spacing desired. i don't cut it all the way through.
Looks very realistic and very simple to do.
redtail 11-16-2017 04:39 AM
You Guys Are Good. Thanks. Chic
