RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   A far better foam for receivers (https://www.rcuniverse.com/forum/tips-techniques-180/11644208-far-better-foam-receivers.html)
Hortco 01-14-2018 09:17 AM
My wife wanted a better foam for her Zero Gravity Chair (for back pain issues)
She talked to someone who said that they could order memory foam to replace the yellow foam in her expensive chair so she bought some and cut it to fit the cushions.
There was quite a lot left and I was out of the yellow foam that I’d always used to wrap receivers, batteries and fuel tanks so I decided to try the memory foam.
WOW! This stuff is amazing!
This foam is far better than the cheap yellow foam for vibration protection! Way way more soft.
i will always use this stuff from here on out!
it can easily be cut into thin sheets to wrap around items in your plane.
This Memory foam is not cheap however
Big Lots sometimes has memory foam pillows at a low price that could be cut and used for vibration protection.
I told my wife about my discovery-she wasn’t impressed.😀
