RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   EZE-KOTE and epoxy compatible? (https://www.rcuniverse.com/forum/tips-techniques-180/11647155-eze-kote-epoxy-compatible.html)
vasek 04-16-2018 10:12 AM
I'm using EZE-KOTE to laminate and would like to use epoxy resin over it (once dried for couple of days) in some arias.
Will it work ?
TomCrump 04-17-2018 02:04 AM
It should be compatible.
You need to wait longer than a couple days, though. Many think that water borne products dry quickly, but that is not always the case.
I suggest that you wait at least a week. Longer, if possible. If you put your epoxy over it before it is completely dry, you may trap a small amount of water under it. When the model is placed in the sun, heat turns the water into vapor, causing blisters.
vasek 04-17-2018 06:11 AM
Thanks for the heads up. Will do.
