RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   Glow engine winter storage (https://www.rcuniverse.com/forum/tips-techniques-180/11685940-glow-engine-winter-storage.html)
billinpa 12-22-2020 12:13 PM
Almost that time, unfortunately. I use Marvel Air Tool oil for afterrun oil, the usual internal saturation. It works well. I have noticed my hi speed needles are getting hard to turn and suspect the O ring is swelling. Should the needle housing/needle and O ring be wet with after run oil when in winter storage? Does this stuff cause the rings to swell? It's very frustrating because these O rings are very difficult to find. What do you all use and the successes you have? Thank you.
Bill
Lifer 12-23-2020 01:07 AM
After run oil is injected directly thru the carb or into the exhaust port so it doesn't directly impact the o-ring. I always run the engine dry at the end of the season and then oil it well for storage.
A supply of o-rings might be had from different sources but the old school method of a fuel line sleeve over the needle valve and the shaft it threads into might be the answer to a new air seal.
JPMacG 12-26-2020 01:25 PM
I store engines in a heated basement. In the summer I run a dehumidifier. The RH is always below 50%. I run the engines dry at the end of each flying session with no after run oil or storage oil. Rust has not been a problem and some of the engines are over 20 years old.
mautro 12-26-2020 02:13 PM
hi
this is almost the same approach as I do it. No problems at all.
