B&D RTX Flex
Is there a flex shaft available for the Black & Decker RTX?
RE: B&D RTX Flex
I have the old B&D rotary tool Wizard I believe, and it came with Dremel front adapter which enables you to use dremel accesories.
Did your RTX came with it? |
RE: B&D RTX Flex
I havent received it yet. I'll check when it comes in.
RE: B&D RTX Flex
ORIGINAL: Swager Is there a flex shaft available for the Black & Decker RTX? |
RE: B&D RTX Flex
Thanks for the inputs!
Im looking forward to playing with my new "toy" |
RE: B&D RTX Flex
You're welcome to ask if you're not sure how to do modifications to Dremel accessories for your RTX, although not all of them need mods. The Dremel right angle attachment, drill press, etc are compatible as well.
| All times are GMT -8. The time now is 02:43 PM. |
