Installing windows in models tips needed
Im ready to install the windows in my Cessna 336. Any one have really good way to do this. It's got lots of glass to put in. Looking for wome different techniques to try
Thanks, Pete |
RE: Installing windows in models tips needed
If the window panels are flat, you can use clear monokote as the window. Real easy to apply and looks like a clear window. This will not work to well if the window has to go around any curves, like most front windshields.
Very carefully ;)
Side windows: A very small bead of adhesive is applied to the edges of the plastic serving as the window. The window is placed and taped in place. The tape stays in the plane . (its inside the fuselage) You have to be careful that there is no excessive glue... or it will get pressed out thecrack between window and frame. Front windscreen: I tend to use a similar method as with theside windpws... but I use trim tape on the outside. (the correct width for the bolt-on frame that retains the glass in the full scale.... if applicable) ******* If going for contest quality scale detail... try to look at a full scale aircraft of the same type and see how they affixed the windshield. simulate that with your installation. (If the windshield is slotted under the front deck... you need a slot to insert yours into or you won't be able to get it on looking correct.) |
If you make a router table for your dremel, you can use one of the thin steel cutters to slot the window frame around the inside. Then cut the window so it pops into the slot. The slot also gives you an easy way to guid the tip of the glue bottle and will help keep the glue from running out and making a mess.
| All times are GMT -8. The time now is 05:49 PM. |
