RCU Forums
-   Tips & Techniques (https://www.rcuniverse.com/forum/tips-techniques-180/)
-   -   stripping black monocote (https://www.rcuniverse.com/forum/tips-techniques-180/1643574-stripping-black-monocote.html)
amelia-air 03-20-2004 02:37 PM
1 Attachment(s)
------HELP----- Trying to strip black Monocote off a Sig Smith Mini. From what it looks like so far,previous owner used Balsarite on all the contact area.I put heat on it from a heat gun--Plastic got gummy,pulled loose ,and left a black residue.Any ideas ? Thanks --
Hircflyer 03-20-2004 03:19 PM
RE: stripping black monocote
I have removed monokote residue with acetone, not easy but can be done.
Stripes 03-20-2004 04:22 PM
Yup, the plastic comes off but the adhesive remains, sometimes so shiny it appears that the plastic is still there. Try using a trim iron. Wipe it on the area and the bulk of adhesive will attach to the iron which you can wipe off on a rag. Then try the acetone for the rest of it. Sometimes I have good luck scraping the adhesive with the side of the trim iron, sometimes I use it like a plow, sometimes I just heat it like I was applying it.
rajul 03-21-2004 01:18 AM
Heat up with a heat gun, and lift the residual pieces with a pair of tweezers
amelia-air 03-21-2004 12:05 PM
1 Attachment(s)
Got just about all of it off,but when I used the acetone ,it turned the wood dark.I hope it don't show through under white Monocote.Thanks for all the tips.wonder if Walmart has a sale on fingernail polish remover --Joann
Kaos Rulz 03-22-2004 12:49 PM
amelia-air - You're better off buying a quart of acetone from a hardware store. The fingernail polish remover has perfumes and oils in it that you do not want on the balsa. (don't ask me how I know) [X(]
amelia-air 03-23-2004 08:54 AM
Hi Ed.
Your right--big difference in price. Is this stuff safe to use in the house ? Cat is clawing at the door ~~holding his nose ..
rajul 03-23-2004 08:57 AM
There is a risk that the acetone in the wood might weaken the glue joints. Check and re-glue if necessary
Kaos Rulz 03-23-2004 10:17 AM
ORIGINAL: amelia-air
Hi Ed.
I wouldn't. The smell is awful and liable to get into the cat food, ice cubes, and unopened beer. :D
